ERROR 000260: Exclude from application evaluation must be enabled [while using sequences.]--The operation was attempted on an empty geometry.
2469
05-18-2021 08:09 AM
GISUSER6
I am trying to publish a web layer with 10 feature classes from a file geodatabase.  The issue I am having may have to do with the new update with Attribute Rules to "Exclude from application evaluation" but I am unsure. When I try to publish the layer to AGOL, it tells me the "Staging Fails". When I open up the log, this is what I see:
Status: Failed ErrorMessage: ERROR 000260: Exclude from application evaluation must be enabled [while using sequences.]--The operation was attempted on an empty geometry.
Status: Failed ErrorMessage: Failed to execute (StageService).
 Status: Failed ErrorMessage: Staging failed
Any idea on what's going on here? I enabled this on all of the attribute rules I am using and ran the repair geometry tool on all of the feature classes.
Thanks!
DanPatterson
Since you have this posted in the ArcGIS Pro community, this is the link to the error message for versions 2.6, 2.7 and 2.8.
000260: Failed to copy <value> into <value>.—ArcGIS Pro | Documentation
which bears little resemblance to your posted error.
... sort of retired...
