env.overwriteOutput in Arc GIS Pro
1737
12-24-2019 10:47 AM
JoeBorgione
People have raised an issue with arcpy.env.overwriteOutput = true after upgrading to arcGIS 2.4.  See: https://community.esri.com/thread/236217-envoverwriteoutput-not-working-after-upgrade-to-pro-24
I haven't run into this issue until today, after upgrading from 2.4 to Arc GIS Pro 2.4.3.  Is this a known bug?
That should just about do it....
DanPatterson_Retired
Joe, you meant
arcpy.env.overwriteOutput = True  # as in the boolean not the lowercase text
Bug? can't find one, but my 'check' works and this is what I use.
https://community.esri.com/thread/236217-envoverwriteoutput-not-working-after-upgrade-to-pro-24#comm...
Bugs listed on support
BUG-000126276: When running the ArcPy script tool in ArcGIS Pro, th..
BUG-000114017: When calling the Change Version ArcPy tool from a cu..
JoeBorgione
Dan- I've had mixed results with arcpy.Exists finding it not nearly as reliable as the straight python counter part. In fact our team adopted arcpy.env.overwriteOutput = True as a standard in our code writing because it has been more reliable.   I'll give it a shot none the less..
