Enterprise Geodatabase Error
2326
8
01-28-2025 08:00 AM
Hala_Ghareeb
Hello,
I have on my machine only ArcGIS pro, is it possible to run the tool "enable enterprise geodatabase" on the connection between ArcGIS pro and PostgreSQL without having authorization file ?
Thank youuu.
A note: I am not asking about creating connection, but I want to make the connected database enabled to be geodatabase, not just a tabular one.
DavidSolari
MVP Regular Contributor
If it's not a method listed in the documentation I doubt you can get a connection going.
Hala_Ghareeb
I've edited the post for more clarification
DavidSolari
Ah, you want to convert a database to an Enterprise Geodatabase, this built-in tool should be what you need.
Hala_Ghareeb
This is not what I need, however thank you
Hala_Ghareeb
Just for knowledge share, this tool also has the same issue of the authorization file needed.
George_Thompson
Esri Notable Contributor
You will have to have a keycodes / authorization file to enable ANY enterprise geodatabase. This requires at any version of ArcGIS Server.
--- George T.
George_Thompson
yes, you should be able to make a connection to a non-Enterprise Geodatabase on PostgreSQL. I have a test PostgreSQL DB (non-geodatabase) that I use on a regular basis.
--- George T.
Hala_Ghareeb
Hi, I've edited the post for more clarification
