Enterprise database connections dropping
11872
12
06-26-2024 10:45 AM
Ona_Tim
I'm not sure if this is the right forum but, I am having an issue with enterprise Database connections dropping to my computer. If I work with ArcPro on the server the connections do not drop. We also made a connection directly from my computer using pgAdmin and will not lose connection even when I loose it in Pro.
My system is as follows:
  1. ArcGIS Enterprise 11.2 Single machine deployment. Server has 32GB of memory
  2. ArcgisPro 3.3.0
  3. Postgres 15.4 Downloaded from ESRI and on a separate server from enterprise. Server has 12 cores and 32GB of memory
  4. Both servers are running Windows Server 2022 datacenter Version 21H2.
When the connection drops I get the following message:
Underlying DBMS error [no connection to the server::SQLSTATE=å] [**unspecified**.**unspecified**.GDB_Items][STATE_ID = 0]
X's replace actual names.
Working with ESRI we found the following information in the logs :
"An existing connection was forcibly closed by the remote host" where host is the PostgreSQL Server and "FATAL: terminating connection due to administrator command". The following PostgreSQL documentation provides more information about the same (https://www.postgresql.org/message-id/5665.1202148155%40sss.pgh.pa.us [postgresql.org]).
At this time IT says it is not a fire wall issue as there are no rules setup for dropping connections. We are at a loss as to what the culprit is.
I will also be posting this in PostgreSQL community to get their input.
Thank you for your help with this.
Ona_Tim
Thank you Ben!
I tested it yesterday into to today and the connection has not dropped.
BenjiMillard
I'm happy to hear that. Glad it worked for you!
eterra
Is this what you changed them to, or was this your default? I am currently experiencing the OP issue and my Keep Alive settings are as follows: idle=120, interval=30, count=9. The client_connection_check_interval=0 but documentation lists it as default/read-only parameter. I'm thinking of lowering my keep alives interval and count numbers and seeing if that helps. I am using postgresql 14.19
