Enabling Data Interoperabilty Extension in ArcGIS Pro with Esri Evaluation Account?
3374
7
10-02-2018 05:32 AM
DambéSANWOGOU
I just created an esri evaluation account to test the ArcGIS DATA interoperabilty extension in ArcgisPro, I assigned the extension in ArcGIS Online to an account. But I can not get access in ArcGIS Pro. How to enable the Data Interoperability extension in ArcGIS Pro ?
DanPatterson_Retired
Did you install it as well
The Data Interoperability extension for ArcGIS Desktop is a separate extension that is a separate install.
… did you authorize it? or is that what you mean by 'assign'
DambéSANWOGOU
Yes i install the extension. but the extension isnot activate in arcgis pro. In attach somes files
Yes my extensions list also shows that I am licensed for it, the version and the expire data... but I didn't install it, so I can't use it, even though it says I am licensed for it
So if you are sure that you did the separate install, I can't help since I don't want to install it to check the remaining needed steps
DambéSANWOGOU
BruceHarold
Esri Frequent Contributor
Your screen shot shows the 10.6 install (32bit), you need to install the Pro extension, in Windows 10 my app entry looks like this:
DambéSANWOGOU
Ok can you send me the download link of the extension I will do it if possible?
BruceHarold
Hi
You can download software from My Esri:
https://my.esri.com/#/downloads
Any problems please talk to your Esri account manager.
