The Emerging Hotspot Analysis tool requires a Space-Time Cube as an input data. Instead of a fishnet grid, I would like to use a honeycomb grids to create a Space-Time Cube. Do the Emerging Hotspot Analysis and Space-Time-Cube creation tools currently support honeycomb grids?
Thank you.
Solved! Go to Solution.
hexagons?
How Creating a Space Time Cube works—ArcGIS Help | Documentation
This will result in either a grid cube (fishnet or hexagon) or a cube structured by the defined locations you provide as aggregation polygons.
hexagons?
