Embedded python code suddenly gone
1181
6
12-12-2024 05:42 AM
RandyMcGregor_BMcD
This happens with some regularity. The embedded script in a python script tool gets replaced by the filepath to to the temp *.py file for the code. I am refraining from using embedding scripts for now because of this but if anyone knows why this is happening, I would be most grateful. It is handy to use embedded scripts. Thank you,
Randy McGregor
DanPatterson
MVP Esteemed Contributor
Edit script tool code—ArcGIS Pro | Documentation describes two methods, only one indicates that the toolbox's embedded code gets updated.
This is apparently a followup to your previous post
Embedded Python Code Disappearing - Esri Community
If the help topics need clarification or this is in error, it may be worth comment in the .... Feedback on this topic? ... link.  I find that comments generally make it back to the appropriate team
PS  I never embed because of the temporary file creation issue/aspect
... sort of retired...
RandyMcGregor_BMcD
Thank you, I have worked with embedded code a fair amount both within the 'properties' execution window and by opening the temporary .py file. Both work fine, and both will update the code, but sometimes the embedded code is simply replaced by the file path to the temporary file, and it's all over. I could have accidentally done this once, but it happens regularly and I'm not quite that absent minded :).
This is most definitely some sort of glitch, whether in ESRI's system or our own, I don't know. The topic explains how to update the code, but what I'm experiencing is not really a problem with the documentation, so not sure what feedback I could provide there. May open a support ticket at this point.
It is a second post. Was hoping maybe someone else might have run into this in the meantime 😕 Anyway, thanks for the feedback. Looks like this one is just a mystery. I will avoid embedding code from now on.
DarinaTchountcheva
Hello Randy,
Just experienced this today and all of my code is gone.
I can recover most of it from copies of the project that I had but not the latest changes.
This is really frustrating.
I am using the embedded code, so I can protect the code with a password and protect users from their curiosity.
I have no explanation of what has happened, but just wanted to confirm that it is not just you that have experienced this.
RandyMcGregor_BMcD
Thanks for the information, but sorry this happened to you. I just gave up on embedded code. This is a VERY weird one. Overall, working with python code in ArcPro has been quite unstable compared to ArcMap. Editing validation code is cumbersome as well. When you open the temp. validation script and edit it and save, you have to close it down and reopen to make more changes as they don't register after the first save.
CarsonMorton
This just happened to me too. I've had it open in visual studio code for weeks and would tinker with it every now and again. I had noticed that the name of my script had changed to some odd name like setmw2bu or something. Then today VSC was blank except for a message about the file not existing.
So, starting from scratch, I have created a .py from VSC instead of Pro. Is that going to keep it safe? Can I run the code in Pro? (I don't see it in the catalog view)
RandyMcGregor_BMcD
I have completely given up on embedded code. I always create a *.py script and load it into the tool. Works fine.
