Edits on multiple sesions.
1339
04-30-2021 08:57 AM
ISMAELAGUILAR
Hi, im wondering if there is a better way of reflect the edits from multiple feature classes saved in session "A" than closing and reopening a session "B" just to refresh the edits an continue editing on session "B"?
The only reason to be making edits in multiple session is that sessions has different coordinate system. Im force to use WGS84 X&Y coordinates to update the feature classes in "A" and make feet and inches measurement modifications on "B", this force me to jump from session to session, thanks in advance.
JMutunga
You can choose how often you want your edits saved and optionally get prompted each time edits are about to be applied. Confirm that these settings match in both of your sessions. Once your edits are saved on one session, pan/zoom your second one and you should be able to see your updates. I hope this helps.
Editing Settings
ISMAELAGUILAR
Hi, thanks for the assistance.
attached is the setting i have for both session.
two minutes of intervals is the adeciduate number to make the edits reflect on both sessions?
