Edits Not Saving within Attribute Table for Hosted Feature Layer
1109
12-09-2025 11:59 AM
McKenzieBredemeyer
When editing a hosted feature layer within ArcGIS Pro, any edits made inside the attribute table are not saved when the layer is reopened in a new project or after the same project is closed and reopened again. The save edits button is pressed every time and the edits stay within the attribute table until the project is closed. Edits made with geoprocessing tools and edits made inside the attribute window are saved when the project is reopened, but anything done inside the attribute table disappears. Anyone else have this problem? This doesn't occur on feature classes in any geodatabase type or shapefiles. I know a solution can be to use geoprocessing tools or attribute window to edit, but there are quite a few times where we don't have enough edits to justify running an entire geoprocessing tool, but enough edits that make it annoying to click through all of them in the attribute window. Using ArcGIS Pro 3.5.4.
RhettZufelt
MVP Notable Contributor
Not that I can really test as I am still using 3.1.3, and 3.2.1, but, in both of these versions, I am not seeing the issue.  Any changes in the attribute table persist, even when closing/reopening or adding to new map.
But, you mentioned 'clicking through all of them in the attribute window' suggests that you have them selected.
Just to make sure you are aware, if you are making the same edit to multiple features, you can click the layer name in the attribute window and any changes made will be applies to ALL selected features at once.  No need to click through them.  Unless, of course, you are making 'different' edits to the features.
R_
McKenzieBredemeyer
Thank you for that reminder with the attribute window. Unfortunately, with this scenario there are still a lot of instances where we are making different edits to each feature.
