Editing Bug: Trace Selected Feature Behavior
7029
16
07-19-2022 08:21 AM
m3
I'd like to report a bug but don't have organizational permissions.
When using the trace tool to reshape polygons, after some unknown amount of time or particular workflow, the tool stops tracing unselected features.
If you can only trace the selected feature, you cannot reshape your polygon - it will only trace what you are trying to reshape.
I can only reproduce the bug by continuing to use the tool until it happens.  I'm unaware if there is any specific situation that causes it.
Workaround:
Change the state of the "Trace selected features only" checkbox (check it if unchecked, uncheck it if checked), clear your selection, then use the tool again.
It doesn't matter what the state of the checkbox is when you do this.  Changing its checked state will change the tool's behavior.
EDIT:  I will attempt to capture a video of this happening next time it happens.  I spoke with 4 others in my organization and they have seen the same behavior.
Scott_Harris
@m3 I think I spoke to you at the UC about this behavior. I wonder if the CTRL key is related to this issue since CTRL is the shortcut to toggle between tracing selected and tracing all (if trace selected is ON).
Thanks for reporting it with all the details. We will test this out. If a bug is logged, I'll be sure to close the loop here.
FYI - another way to limit what features can be traced is to toggle snapping on or off for a particular layer in List By Snapping (Contents pane). Only snappable layers can be traced. TIP: In List by snapping, a quick way to toggle snapping for a particular layer is to right click on it and choose > "Make this the only snappable layer"
Scott
m3
Yes, we did speak.  I will try the CTRL key and report back.  I'm wondering if this could be related to remote desktop sessions key mapping as we are all working remotely.
We had a large project where we were only tracing particular layers. We discovered this problem during that project.
Thank you for the tips!
Scott_Harris
@m3 So far, I can't reproduce this behavior, but in researching it, I found there was as bug that was fixed in 2.8 related to 'Trace only selected features': [BUG-000136504 The 'Trace selected features only' check box option for the Trace tool is automatically checked.]
It involved hitting the CTRL key to select multiple features in the Attribute Table, which inadvertently switched on 'Trace selected features only' when you revisited the map. Like I mentioned, this was fixed in 2.8 - so if you are using 2.8 and above, and you see this behavior, please provide reproducible steps to me or Esri Technical Support so a bug can be logged and tracked by other customers who contact Support.
Thanks!
-Scott
PeteJordan
Hey @Scott_Harris,
  Ahhh, got me again with my extensive use of mutiple accelerators and guess what?  My Reshape (esri_editing_ReshapeCommand) is set to <CTRL-R>, Trace (esri_editing_ReshapeCommand) set to <Alt-R> and this is the problem.
  Tried it without using my accelerators and yes, it now works and I don't have to close down ArcGIS Pro each time I want to do a trace polygon at all.
  So I assume this is on the bug list correct for a future fix when those accelerators all get that possible overhaul in an upcoming version then?
  I'm glad @m3 already had this asked as I was about to fill out another bug report (until I saw this thread) and his video is much better than my images...
m3
Well here's a video of the trace tool not tracing a non-selected feature when the "Trace selected features only" box is not checked.
I was able to change the behavior by hitting the CTRL key but it required I unselect the polygon first.
LOL, sorry for the "triple negative"
(view in My Videos)
Scott_Harris
@m3 Thanks for the video. Yeah that's definitely unexpected. Which version of Pro?
m3
It was the same behavior on the last version I used but I do not know how far back it goes.
It's hard to tell you how to reproduce it because I've been using the align edge, align features, merge, reshape with and without trace tools for about 2 hours before it happened.  When merging, I will use the CTRL key not in the attribute table, but in the map to deselect.
m3
Here's another very awkward video of me fumbling through the trace selected features options.  Here you can see it doing the opposite behavior.  I have a trackball mouse I'm not used to so that's the reason for the jerky movements.  What's happening outside the video is that I'm using the trace reshape tool and the deselect tool.
The start shows it tracing selected when the box is unchecked
The end shows it tracing unselected features when the box is checked.
(view in My Videos)
m3
One more bit of information.  The Trace selected features only checkbox may only have this bug using the reshape tool.  I noticed it works as expected and immediately when using the split tool.
