Edit fields not working
983
07-25-2025 09:54 AM
AvaFarouche
Greetings!
I am not able to edit my data table. I've done this countless times. I just did it yesterday in a different attribute table in the same project. I've added two attribute fields so I can add two separate, additional numerical identifiers to property parcels. So I added the attributes, but now when I go in to add/ edit the text in the table it just disappears as soon as I move on to the next entry and returns to a "0" entry. I restarted my software and my machine. I'm in an edit session with the appropriate layer selected.
Any ideas??
Thank you so much!!
MErikReedAugusta
MVP Regular Contributor
When I first saw the title of this, I assumed the issue was going to be one of two things:
  1. Your user account didn't have permissions to edit that feature class in your Enterprise or similar system
  2. You do have permissions, but in your currently-active map, the feature layer is unchecked in the Selection Tab of the Contents Pane (see image below)
What's weird, though, is that if either of those were true, then the fields should be greyed out in the attributes pane and wouldn't allow you to alter any cells on the attribute table.
What your post seems to describe is that you're able to make an edit, but the edit immediately reverts as soon as you move to another field.  If that's the case, there are (again) only two reasons I can think of:
  1. You're attempting to add a value of the wrong type to the field.  (e.g., it's an integer field, and you're trying to input text)
  2. The field(s) in question have an Attribute Rule or something similar tied to them, and the script written in the rule is overriding your entry.  You'll need to review the logic in that rule and figure out if there's a logic error somewhere.
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
MErikReedAugusta
M Reed
AvaFarouche
Greetings!
Yes, you are correct. I actually figured it out myself before I saw your response. When I created the field, I designated it as Short because I intended to only use numbers, but then I changed my mind and decided to include an alpha prefix in the same field, and that's what messed it up. Thanks for chiming in! And I love your signature quote. It's better to be happy than right.
