Edit feature failed
2019
09-21-2022 10:11 AM
SaraIhrie
I am having issues with editing--or rather, deleting--points in Pro. Whether I open an existing project file, import a layer file either from my organization's online portal or from a newly packaged layer, and despite having no read-only or protective settings enabled, I get error messages when trying delete erroneous points.  A pop-up window with the title "Delete Features" with a red x graphic and the text "Edit operation failed" appears, and the points do not get deleted. Attached is a screenshot.
My ArcGIS Pro version is 2.9.4, which is the most recent my organization allows.
I am accessing Pro on a Windows 10 Enterprise operating system (Dell Latitude 7410 laptop).
Any ideas on what I can do?
jcarlson
Are deletes allowed on the service itself? Some services can have specific permissions on them disallowing deletes.
- Josh Carlson
Kendall County GIS
SaraIhrie
Yes. My supervisor can delete points, and we are categorized as "Creators" equally within our permissions--though he has not switched over to ArcGIS Pro (he is working off ArcMap, which I no longer have access to).
Scott_Harris
@SaraIhrie
What does List By Editing within the Contents pane show? Any warning badges?
What does the Editing Status window show? Any warnings, messages, etc?
More info:
https://pro.arcgis.com/en/pro-app/latest/help/editing/specify-which-layers-can-be-edited.htm
https://pro.arcgis.com/en/pro-app/latest/help/editing/view-layer-permissions-for-editing.htm
If no useful information shows, perhaps a call to Esri Technical Support can help you resolve it.
-Scott
SaraIhrie
Hi, Scott:
No warnings appear in the Contents Pane List by Editing window (as related to the layer in which I am attempting to delete points, at least). The Editing Status shows the layers that I cannot edit as such, but confirms no issues related to the layer in question. Thanks so much for the info, all the same. I will attempt to get Esri Tech Support on the line.
Hala_Ghareeb
You could overwrite the layer and make sure that you allow to edit the service without m-value
