Dynamically filter and edit features — based on query to related table
1035
11-07-2022 08:47 AM
Bud
Legendary Contributor
Oracle18c EGDB
I have a feature class called EVENTS (fields: EVENT_ID, EVENT_YEAR) and a related table called FUNDING (fields: EVENT_ID, FUNDING_YEAR).
I want to filter (display in the attribute table) events where there are related funding rows from other years. For example:
  • Show a 2022 event that has funding from years other than 2022:
    • Funding in 2021, 2023, etc.
    • (it doesn't matter if there is funding from 2022 or not)
  • Don't show events that only have 2022 funding rows. And don't show rows that have no funding rows.
I want the filter to be dynamic. And I want the event rows to be editable. I don't need to display any fields from the related table.
What are my options?
  1. Create a definition query that has an SQL subquery that points to the related table:
    event_id in (
        select
            e.event_id
        from
            events e
        left join
            funding f
            on e.event_id = f.event_id
        where
            e.event_year <> f.fund_year
            and e.event_status in ('F','P','A','C')
        group by
            e.event_id
    I can edit the events in the attribute table.  No joins required.
  2. Or, create a database view that selects the applicable funding rows. In ArcGIS Pro, create an in-map join (only matches included) to the view via the common EVENT_ID. Edit the events in the event attribute table.
    1. Or, instead of an in-map join, create an in-map relate. Select all funding rows and use the Attribute Table tools to select the related event rows.
  3. Or, do #2 above, but use a Query Layer instead of a database view.
Are there any other options or anything I've overlooked?
Thanks.
