Duplicates projects Question
1296
03-18-2024 08:25 AM
DEAF_PROBERT_68
Honored Contributor
I have a question about ArcGIS Pro I have and it is about many projects I saved.  Is there a way around to know if one of them have the same as others ?
I am talking about insert New Map for many saved projects ....
It is about too many duplicates that I need to get rid of .
Do you have any feedback for me ?
I may have had too many projects that I brought to VDI from PC.
Currently I am working in VDI.
DanPatterson
MVP Esteemed Contributor
There is no way to find out if projects are duplicates.  Using windows file explorer might give you a clue if you saved your projects in one location, but if you don't manage your file saving locations and naming conventions, you will have the task of opening each and deciding which ones are worth keeping... as with many spring cleaning tasks
... sort of retired...
DEAF_PROBERT_68
Honored Contributor
Thanks Dan !  What I would do is open each project and look and then share a Map file as a new name and save them in a folder....
Yes a lot of work.
DEAF_PROBERT_68
Honored Contributor
And before delete it, check Geodatabase too !!
