Drawing a line feature at a constant slope using elevation data?
1533
01-04-2022 06:45 AM
Hemlock_Grove
I build trails that need to meet certain accessibility requirements. One of the requirements is having a certain running grade (slope).
I have used 2ft. contours and some basic math in the past to get a rough idea of how conducive a terrain is to meeting said requirements, but I am wondering if there is a more precise and/or automated way to draw a line that crosses contours (or uses a DEM layer?) at a constant steady slope.
For example, if I wanted to draw a trail that traverses a hillside at exactly 10% grade, could I utilize elevation data to construct this?
I'm a somewhat novice Arc user, so highly advanced/custom methods are probably out for me. Thank you!
Tags (1)
Hemlock_Grove
Let me ask this question a little differently, hopefully with it leading to a more straight forward answer:
Is it possible to calculate/determine the slope of line feature, even if the line feature is just arbitrarily drawn? And by line I suppose I really mean a straight line (slope between two points). I know it's possible to draw a slope/aspect model with DEM, but the lines I would be drawing traverse these slopes.
