Double an attribute table within a Report
1246
02-09-2022 02:21 AM
MartinJacquet38
Hello,
I'm trying to export an attribute table in .pdf. I've tried to do so within a layout with a Table Frame object, but I haven't found a way to display the whole table.
I am now working with a Report which can generate as much pages as needed , but I'd like to format it a bit more. In fact, I'd like to double the fields so the output will have roughly half the pages it has now.
I duplicated the "Details Field Value Text" but as I expected it just display twice the same information :
How could I make the Report display the next data in the right part of the sheet, and not on the next page ?
Thanks for your help.
JoshSaad1
I recommend copying the table rows to Excel or running the Table to Excel geoprocessing tool. If all you need is the table, I've found Excel to be much easier to design reports with.
MartinJacquet38
Hello, thanks for your answer.
However, I would like to keep it as automatized as possible, the goal of this index is to be inserted in a Map Series pdf output. I have +/- 500 .pdf to create so I really can't do it manually.
