Donut around points in ArcGIS Pro
219
07-03-2024 11:16 AM
GIS243
Hi, how do I create a donut around points in ArcGIS Pro, please? I have tried the Erase tool, but I'm not getting the result I want.donut around points in ArcGIS Pro.png
Thanks for the help please
Georgios-NektariosTselos
Hello @GIS243  I suggest to follow the next steps, i think you will help you to make it.
  1. Click the Edit tool. on the Editor toolbar.
  2. Click the feature around which you want to create a buffer.
  3. Click the Editor menu and click Buffer.
  4. Type the distance in map units for the buffer area around the feature.
  5. Choose the target in which the new feature will be created. ...
  6. Click OK.
However you can check this link for more informotation about buffer zones(Donut)
https://pro.arcgis.com/en/pro-app/latest/help/editing/create-a-2d-or-3d-buffer.htm
Best Regards
Georgios-Nektarios Tselos
BobBooth1
This tool might also work for you.
https://pro.arcgis.com/en/pro-app/latest/help/data/distance-direction/create-rings.htm
Could delete the internal circle/ring to get the donut.
