Domain will not allow codes to be added
1091
03-11-2025 09:58 AM
FlightDeck
Hey all,
I created a domain within a project with Yes and No as the only 2 codes available and it worked as it should. I now need to add another domain for a different field. I can add the domain with no issue, however, as soon as I attempt to add a code to the new domain I lose the ability to save the domain. The domain and the codes go from having the green square to a red square next to them and I can go no further in the process just by adding the code line. If I remove the code lines I can again save the domain and even add it to the desired field. any idea what might cause this?
FlightDeck
Turns out the Description Field is required and the code will not save until that is filled in.
FlightDeck
