Hy,
I have some questions about Maplex.
I ask this because I notice differences in rendering between the two products.
Flavie
Solved! Go to Solution.
Hi Flavie,
The Maplex Label engine is kept in sync between the latest releases of ArcMap and ArcGIS Pro. If you are seeing differences please send examples.
thanks
Wendy
Hi Flavie,
thanks
Wendy
Hy Wendy,
Thank you for this information.
I will ask to my client the differences. I'll come back to you soon.
Best regards,
Flavie
Hy Wendy,
Here are the differences between ArcGIS Desktop/PRO for a same Maplex configuration and same data.
ArcGIS Desktop 10.2.2 side ==> Have a look on texts highlighted in red
ArcGIS Pro 1.3 side ==> Have a look on texts highlighted in yellow
The difference is on ArcGIS Pro side it miss some texts.
Is it the same version of Maplex between ArcGIS Pro 1.3 and ArcGIS Desktop 10.2.2?
Flavie
they aren't the latest releases of pro and arcmap (1.4.1 and 10.5). Was your pairing of pro 1.3 and map 10.2.2 and equivalent pairing at the time?
ArcGIS Pro was first released with ArcGIS Desktop 10.3. And What's new in ArcGIS Desktop 10.3 (Labeling) include
The Maplex Label Engine in ArcGIS 10.3 has improved stability, scalability, and performance.
Placement improvements include the following:
- Improved integration between street labeling and key numbering
- Better placement along curved roads and rivers
- Labels using the Never Remove parameter have improved faster placement
- Improvements in aligning contour labels to the page and elevation
- Labels with callouts and leaders now take halos into account when placing and have improved performance
So you can expect some difference between ArcMap 10.2.2 and ArcGIS Pro.
Have you compared labeling between ArcMap 10.4.x and ArcGIS Pro 1.3?
Thanks for all these explanations.
I do not have tested since ArcGIS Desktop 10.4. My customer do not installed this version.
I will see with him to do this test.
Best regards,
Flavie
Hy,
Indeed, there is no difference of label between with ArcGIS Desktop 10.4 and ArcGIS Pro 1.3.
Thank you all for your advice,
Flavie
You are welcome...
