Does License Manager 2023.0 fix BUG-000157210?
1920
10-16-2023 09:49 AM
MikeGarcia
Running ArcPro 3.2 with 11.1 Enterprise in Azure using License Manager 2022.1
We experienced a similar issue to BUG-000157210 where our Windows Server 2022 Datacenter Azure Edition lost communication to the 2022.1 License Manager, even though they are on the same machine.
I tried to run the Diagnostic in LM but couldn't get it to display a "System Binding changes detected" message.  The logs said "Wrong hostid on SERVER line for license file: ..." (Rather than the correct VM_UUID=, we had VM_UUID={"apiVersions": ["2017-03-01", "2017-04-02") ...then all the licenses were disabled.
The BUG states the only workaround is to:
  1. Uninstall ArcGIS License Server Administrator 2022.1.
  2. Reinstall ArcGIS License Server Administrator 2021.1.
However, this solution is from July 17, 2023, before the release of LM 2023.0
I am wondering if the new License Manager 2023.0 fixes the BUG in 2022.1.
Thanks for your help!
JoyMiles
I can confirm that it is not fixed
George_Thompson
Esri Notable Contributor
I would reach out to technical support regarding this defect to see if there is any other information / update that could be provided.
--- George T.
JoyMiles
I have done just that and there is no fix.
