Does ArcGIS Pro support MS Access 2007 (accdb)?
1320
09-26-2024 08:51 AM
JeffHouser
In ArcGIS Desktop I was able to connect to a *.mdb access database which contained the topology and data.
Based on some searches, suggest this is doable if the *.mdb is converted to *.accdb, and then use the Microsoft Access databases can be read in ArcGIS Pro using the OLE DB database connection.  I have stepped thru this, and can see the table in "Catalog", but the topology does not show up.
Does ArcGIS Pro support MS Access 2007 (*.accdb)?
Thank You,
~ Jeff
JeffHouser
Thank You Justin.  I did come across the esri support that you mentioned info as well.  In ArcMap Desktop, we have been using a personal access database to hold topology and the data, and used a Access form as the graphical interface.  Try to adapt this personal database w/ form in ArcPro.  Do you you know a way to do this?
~ Jeff
