Does ArcGIS Pro sees this field as an hyperlink file:///\\server\documents\ID
768
12-19-2023 05:42 AM
JoseSanchez
Hello  everyone,
ArcMap see this notation file:///\\server\documents\ID  as an hyperlink, so when I identify a feature and click on the Hyperlink Tool it opens the folder.
Is the away to do the same thing with ArcGIS Pro?
George_Thompson
Esri Notable Contributor
You may want to look at this post, if you are using Pro 3.2: https://community.esri.com/t5/arcgis-pro-questions/hyperlink-not-working-arcgis-pro-3-2/m-p/1362155
--- George T.
