Django and arcpy
697
04-11-2025 12:35 PM
KiroAndreevGDI
i have Django project which use arcgis pro environment. Whet write import arcpy into view.py appear error:
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\runpy.py", line 198, in _run_module_as_main
return _run_code(code, main_globals, None,
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\runpy.py", line 88, in _run_code
exec(code, run_globals)
File "c:\program files\microsoft visual studio\2022\community\common7\ide\extensions\microsoft\python\core\debugpy\launcher/../..\debugpy\__main__.py", line 71, in <module>
cli.main()
File "c:\program files\microsoft visual studio\2022\community\common7\ide\extensions\microsoft\python\core\debugpy\launcher/../..\debugpy/..\debugpy\server\cli.py", line 501, in main
run()
File "c:\program files\microsoft visual studio\2022\community\common7\ide\extensions\microsoft\python\core\debugpy\launcher/../..\debugpy/..\debugpy\server\cli.py", line 351, in run_file
runpy.run_path(target, run_name="__main__")
File "c:\program files\microsoft visual studio\2022\community\common7\ide\extensions\microsoft\python\core\debugpy\_vendored\pydevd\_pydevd_bundle\pydevd_runpy.py", line 310, in run_path
return _run_module_code(code, init_globals, run_name, pkg_name=pkg_name, script_name=fname)
File "c:\program files\microsoft visual studio\2022\community\common7\ide\extensions\microsoft\python\core\debugpy\_vendored\pydevd\_pydevd_bundle\pydevd_runpy.py", line 127, in _run_module_code
_run_code(code, mod_globals, init_globals, mod_name, mod_spec, pkg_name, script_name)
File "c:\program files\microsoft visual studio\2022\community\common7\ide\extensions\microsoft\python\core\debugpy\_vendored\pydevd\_pydevd_bundle\pydevd_runpy.py", line 118, in _run_code
File "D:\GDI\M19_AKN_NadgradbaNaNIPP\GISPython\manage.py", line 24, in <module>
execute_from_command_line(sys.argv)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\django\core\management\__init__.py", line 442, in execute_from_command_line
utility.execute()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\django\core\management\__init__.py", line 416, in execute
django.setup()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\django\__init__.py", line 24, in setup
apps.populate(settings.INSTALLED_APPS)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\django\apps\registry.py", line 91, in populate
app_config = AppConfig.create(entry)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\django\apps\config.py", line 193, in create
import_module(entry)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\importlib\__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1204, in _gcd_import
File "<frozen importlib._bootstrap>", line 1176, in _find_and_load
File "<frozen importlib._bootstrap>", line 1140, in _find_and_load_unlocked
ModuleNotFoundError: No module named 'corsheaders'
Press any key to continue . . .
I instaled corsheaders with:
pip install django-cors-headers
but this error appear again.
Is it possible to use arcpy into Django project?
How to solved this problem?
Best Regard
