Distance Accumulation attributes
439
06-05-2026 12:13 PM
HeatherFox1
I have created a distance accumulation raster using a road layer, and I'm wondering if there is a way to attribute the raster with the road information that it is measuring the distance from. The goal is to know how far a location is from a road, but I would like to know what type of road it is. Is this possible? Or is there an alternative way to go about it?
Robert_LeClair
Esri Esteemed Contributor
Yes—use Distance Allocation (instead of only Distance Accumulation) so you get both:
  • a distance raster (how far to the nearest/least-cost road), and
  • an allocation raster that stores which source each cell is assigned to.
Try these steps:
  1. Run Distance Allocation with your roads as the Input raster or feature source data.
  2. Set Source field to a road attribute you want carried through (for example ROAD_TYPE), or better, a unique key like ROAD_ID.  This must be an integer field though.  So perhaps you calculate a ROAD_TYPE field of 1 for interstate, 2 for US Highway, 3 for State Highway and so on.
  3. Use the outputs:
    • Output Distance Accumulation Raster = distance to the closest/least-cost road.
    • Output Distance Allocation Raster = the value of your Source field for the road that each cell is allocated to.
DanPatterson
MVP Esteemed Contributor
Perhaps, densify your road layer, then convert points (all vertces), then extract the raster information to those points.
Extract Values to Points (Spatial Analyst Tools) | ArcGIS Pro documentation
... sort of retired...
Robert_LeClair
Try these steps:
  3. Use the outputs:
