Dissolve / Pairwise Dissolve generates error
11008
11
06-11-2023 03:50 PM
Labels (3)
Mikhail
I have a shapefile with small polygons, that I need to merge into larger ones. Merging should be by a specific variable, conparid, which is available for any polygon. I am trying to use the 'Dissolve' and 'Pairwise dissolve' tools, but receive a message 'WARNING 000117: Warning empty output generated'. I successfully ran 'Repair Geometry' and 'Check Geometry', but this did not help.
Eventually, I simplified my dataset to include only two polygons, which I am trying to merge. Please see the screenshot attached. I wonder what could be wrong, and would appreciate any suggestions.
Tags (3)
DanPatterson
MVP Esteemed Contributor
Perhaps you could "Accept as Solution" the thread that provided the answer so that it can be discovered by others in your situation
... sort of retired...
DanPatterson
do you have a csv file joined to the source table?  Your dissolve field needs to be part of the input featureclass.
Also, dump the shapefile and make a featureclass in a geodatabase and do the dissolve on it.
If you need a shapefile after, then export it to one.  It just removes a big place where things can go wrong.
Dissolve (Data Management)—ArcGIS Pro | Documentation
You just need Dissolve when things are properly structured for the input.
Mikhail
I have a shapefile with small polygons, that I need to merge into larger ones. Merging should be by a specific variable, ConPar, which is available for any polygon. I tried the 'Aggregate Polygons' tool but it wants to merge all polygons within a certain distance and does not accept zero. In my case, polygons border each other. Could you suggest the right approach?
Tags (3)
LanceCole
Did you try the Dissolve Tool?
Mikhail
Thank you! This looks like the right tool, but when I run it I get WARNING 000117: Warning empty output generated. I've also tried 'Pairwise dissolve' and ran into the same problem. Do you know what could have caused it?
LanceCole
@Mikhail,
Without seeing your data and how you are running the tool, it is difficult to know why the error is occurring.
  • The input for the tool needs to be a feature layer
  • Check the geometry on the input feature
  • make sure the common attribute is actually the same
  • select a small number of features you know would be dissolved and test just those
  • look through the geoprocessing result and see if there are any addition errors
  • do you have write assess to the ourput location
Mikhail
Thank you! I have tried all this, but nothing helped. I have even reduced my dataset to two neighboring polygons and tried dissolving them into a single unit...no luck so far.
DanPatterson
PS, don't repeat questions, they get merged in any event... just saves us time keeping things organized
Mikhail
Dear Dan,
Sorry for duplicating my question, I did not know how the system works.
Thank you for your advice! You are right, I joined the csv table to a source table, and the grouping variable conparid was in the original csv file. Now I created a new variable 'merge' and set is equal to 'conparid' so that merge belongs to the input feature class. Unfortunately, nothing changed.
Could you please explain what you mean by dumping the shapefile. Where would it go?
Regards,
Mikhail
DanPatterson
Copy Features (Data Management)—ArcGIS Pro | Documentation
shapefile as input
geodatabase featureclass as output
Then do the dissolve ensuring that all joins are permanent and you have a clean unjoined field to dissolve on.
Reverse copy features using the result as input and a shapefile as output... but skip shapefiles if you are using Pro (agol, arcgis api for python, or 3rd party aps may be exceptions),
there is no need for them now because of their limitations
