Display fields with domain from another table in pop-up window
583
04-10-2026 11:54 AM
AmyRoust
I used the code block from this Esri article to pull records from a related table:
https://support.esri.com/en-us/knowledge-base/display-fields-from-a-related-table-in-the-pop-up-wind...
My problem is that one of the fields in the related table has a domain assigned to it, and the Arcade code block is returning the code from the domain table instead of the description. How can I tell it to pull the description? Looking at line 10, related_data_row.field1_table of this:
var related_table = FeatureSetByName($datastore, "table");
var filter_query = "field_table= '" + $feature["field_class"] + "'";
var related_data_filtered = Filter(related_table, filter_query);
var related_data_filtered_count = Count(related_data_filtered);
var output = "";
if (related_data_filtered_count > 0) {
	output = "Total of " + related_data_filtered_count + " records : ";
	for (var related_data_row in related_data_filtered) {
		output += '<br>' + related_data_row.field1_table+ " - " + related_data_row.field2_table;
} else {
	output = "No Related Records...";
return {
	type : 'text',
	text : output
KenBuja
MVP Esteemed Contributor
Use the DomainName function to get the description
output += '<br>' + DomainName(related_data_row, "field1_table") + " - " + related_data_row.field2_table;
Also, you can simplify the code a little bit
var output = "No Related Records...";
KenBuja
AmyRoust
Thanks, Ken! Worked perfectly.
