I created a web map in ArcGIS Pro which was uploaded to ArcGIS Online. Upon opening the web map in ArcGIS Pro, I realized that whenever I zoomed into the map, the satellite imagery disappeared (and even the basemap). Everything apart from the point layers just turns white. How can this be resolved?
I am sorry to hear that, did you try adding each hosted feature layer one by one to Map Viewer and see if they Zoom in and out fine?
Thanks. I tried this method and still the problem persists.
check the properties of the layer and see if it has a properly defined coordinate system as well
Thanks, I checked this and it does.
Much thanks for the response. I think I did this before, but, I will check it again.
What basemap are you using in your web map?
I am using the Light Gray Canvas.
Before you publish the web map from ArcGIS Pro, I'd recommend building Raster Statistics and Pyramids using the Build Pyramids and Statistics (Data Management) GP tool first. Then republish your webmap. Does the behavior persist?
Thanks. I'll try this and see.
