Disable map 'momentum' when panning with mouse
1045
07-12-2024 01:29 AM
RTPL_AU
How do you disable the 'momentum' of a map window when you pan using the centre mouse button.
I do not want the map to keep moving when I release the button after a fast pan.
jcarlson
Agreed! If your hand has a slight tremor to it, a tiny panning movement can "throw" you pretty far from your initial view.
Fortunately, there is a setting for this: panning gestures.
Turn it off, and you're good to go.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
