Is it possible to disable the checkbox "Auto Apply" in the attribute table?ScreenCapture.PNG
"Auto Apply" , whether it is checked on or off by default is tool dependent, there is no way in the Project, Options backstage to disable or enable it in any state.
Thank you for your explanation.
@OscarYam The Auto Apply checkbox in the Attributes pane remembers its state (checked or unchecked) at the application level - meaning that if you check it ON and close Pro and then open a new project, the checkbox will remain ON. Is that what you see on your end?
