Difficulty Modifying Geodatabase Annotation
655
05-22-2026 12:41 PM
DaveMartin1
Hello, I'm attempting to modify annotation that was originally feature linked annotation in a MXD file.  I've inserted an MXD to create a new APRX project. I have a GDB file in the APRX containing HouseNum_Anno. I ran the Upgrade Dataset tool on the Anno feature class  . That succeeded (as far as I could see). I set my Anno and Parcel layers as selectable. When I go Edit > Annotation tool, and try to select the Annotation (graphically) in the Map window, the annotation doesn't select.
Anyone know what I'm not doing right?
Dave
DaveMartin1
Hey folks,  It turns out the Upgrade Dataset DID work for me.  My problem was I was trying to select the annotation with a single click of the Annotation Tool. That did not select.  When I double-clicked the annotation, it did select and was editable.  Case solved
DaveMartin1
Is it people's understanding that GDB annotation is not 'editable/modifiable' (even after the Geodatabase has been upgraded)?
JMutunga
@DaveMartin1  Could you confirm if any error message appears on the annotation layer in Contents pane? I took this screenshot of an MXD I imported in ArcGIS Pro BEFORE running the Upgrade Dataset tool. If the tool runs successful, that message/badge should disappear and you should be able to select and edit the features with the Annotation editing tool.
It is always advisable to backup your data and understand all limitations before running the Upgrade Dataset geoprocessing tool.
Debert
I really wish we could publish feature class annotations as a feature layer. I've logged an enhancement for that here.
Cheers!
I am the GIS Coordinator for Iowa Regional Utilities Association.
Find me on Linkedin.
DaveMartin1
