Difference between minimized floating window vs. closed
517
01-31-2025 12:53 PM
Bud
Legendary Contributor
In ArcGIS Pro 3.4.0, what is the difference between minimizing a floating window like the Attribute Table vs. closing the window? Does the data in the Attribute Table only get refreshed if closed/re-opened, not when minimized/maximized?
Robert_LeClair
Esri Esteemed Contributor
From testing, the attribute table gets refreshed when there's a new edit - add/update/delete so no manual refresh needed.  When one minimizes the table, it minimizes to the task bar (on the bottom of your screen) in a way.  You can hover your mouse over the ArcGIS Pro icon on the task bar and you'll see the minimized table and can maximize it by clicking the table icon.  If you click the X to close the table, it closes/disappears. Then you'll need to reopen the table via a right-click on the layer in the Contents Pane-> open or select the layer in the Contents Pane and hit your CTRL-T hotkey to open the table.
