Detect Object Using Deep Learning Error 999999 When GPU in used
208
06-26-2026 06:55 AM
chunboli
I am using Arcgispro3.01 version of Detect Object Using Deep Learning, and the paths are all in English. When I set the processor type to GPU, the prompt is as follows:
ERROR 999999: 异常错误导致工具失败。 请联系 Esri 技术支持 (http://esriurl.com/support) 以报告漏洞,并参阅错误帮助以获取潜在解决方案或解决方法。
并行处理作业超时 [Failed to generate table]
执行(DetectObjectsUsingDeepLearning)失败。
运行 失败,结束时间: 2026年6月26日 21:36:12 (历时: 4.43 秒)
And when I switched to CPU, it ran normally. Why is this and how can we solve it?
I also use GPU when building deep learning models, which can run.
Some people say it's because of using a cracked version.
Thanks.
chunboli
I didn't set the parallel processing factor when using the GPU
