Design/Fields View NOT Saving
3224
07-18-2023 02:16 PM
Craig_Eissler_Iceman
When I make changes in the Design/Fields View, and click Save, they do not save.
For instance, when I change the Alias to something else or re-order the fields; it is NOT saved after I close the Table, Remove it from Contents, then add it back to the Project.
This feels like a BUG..?
Robert_LeClair
Esri Esteemed Contributor
So to make an alias change permanent, at the top of the Fields Designer is a dropdown menu with the name of the current layer.  Click the dropdown and choose Data Source.  Then any and all alias changes are saved to the Data Source.  When you remove it from the Map View, add it back in, it will remember the alias change.  From a very long time, reordering of fields is never remembered.  It's on the wish list - there's a lot of ArcGIS Ideas for that item.
Robert_LeClair
Ah, thanks -- I never realized that was there!
But OK, it worked now. Interestingly, however, is that it did permanently change the formal Field Name without having to make the Data Source switch.
JessicaJThompson
Any way to apply the layer aliases to the data source without manually typing them? Or copy and paste?
