Densify Tool failed in Pro with SDE data
1907
09-26-2019 09:56 AM
LeeBrannon1
In ArcGIS Pro 2.4.1, I was trying to use the Densify tool on a line feature class from SDE (SQL Server) with one line feature selected.  The line feature has both straight and true curve parts to it.  I'm using the Offset Method with the value set at .5 feet.  Densify fails.   ERROR 000224: Cannot insert features
The tool works just fine on the same feature class when I export it to a File Geodatabase.
Anyone know if this is a Bug?
JoshuaBixby
MVP Esteemed Contributor
Have you confirmed you have proper permissions on the feature class in SQL Server?
LeeBrannon1
Yeah, I'm working with my version in our editable database.
Robert_LeClair
Esri Esteemed Contributor
I too am seeing this with a PostgreSQL feature class.  Me thinks it's a bug. I'd recommend contacting Esri Support Services to log an incident and get a bug number.
LeeBrannon1
I agree, Robert.  I will call support and make them aware it needs their specific testing.  Thanks.
