Deleting a Feature Class in a File GDB
1603
06-19-2023 02:42 PM
RyanXiong
Hello,
I have a situation where I try to delete a Feature Class in a File GDB, and it shows an error below.
 However, after refreshing the File GDB, the Feature Class is deleted. This is the outcome I would want, but I'm just curious if the is an issue with the Feature Class and is this something I should be worrying about?
Also, I create the data from exporting feature class from from a Parcel Fabric, which I assume may be the cause of this.
Best,
Ryan X.
RyanWalter
No - not a problem. You're probably right on the cause though. It shouldn't cause any issues
