Delete Text from ArcPro
1783
11-18-2024 02:00 PM
NicoleCyr
I imported a map from the desktop version of ArcMap into ArcPro. In the original map I had text boxes. I want to delete them in the ArcPro map and cannot figure out how to. Please help!
Eugene_Adkins
If the text is in a layout, you should be able to right-click the text in the contents pane and then choose the delete option.
If text is in a map you can select the text in the map itself using the select tool and then right-click and choose delete.
Eugene_Adkins
NicoleCyr
Thank you!
JesseWickizer
If the text was map annotation in ArcMap, it will be imported to a Map Graphics layer in the map. To select and then delete these text elements, use the Select tool on the Graphics ribbon.
