Definition Query with dates
13198
6
07-01-2021 05:35 AM
GregorCalderwood1
HI,
I really hope someone can help me out with this. I have a definition query defined on a feature class coming from an Oracle SDE where a date field is queried to return values within 6 months of the current date (see below)
RELDATE_DATE > ADD_MONTHS(TO_DATE(SYSDATE),-6
We are in the process of migrating to a PostgreSQL SDE and with the same feature class the query no longer works or is verified ( returns an error)
What should my new definition query look like?
The feature class filed being queried is RELDATE_DATE
Thanks
Gregor
Tags (3)
jcarlson
Try this:
RELDATE_DATE > (NOW() - interval '6 months')
EDIT:
It looks like you can't use those functions in Pro, even if the DB itself would in a query. Try this instead:
RELDATE_DATE > (CURRENT_DATE - 182)
- Josh Carlson
Kendall County GIS
jcarlson
Try this:
EDIT:
- Josh Carlson
Kendall County GIS
GregorCalderwood1
Hi Josh,
Thanks for the response - the RELDATE_DATE > (CURRENT_DATE -182) works.
Thanks very much
AlinaTarmu_SCGIS
I have a similar issue with a definition query. This
works when it is not combined with other conditions. The moment I add others, it throws an invalid syntax error. Here is my expression:
(CLASS = 'first' Or CLASS = 'second' Or CLASS = 'third' Or CLASS = 'fourth' Or CLASS = 'fifth' Or CLASS = 'sixth' Or CLASS = 'seventh' Or CLASS = 'eighth') And EQUIP = 'X' And Date_Created > (CURRENT_DATE - 182)
Basically the bolded part works, but when I add the date filter, I get an error. (I am in Pro 3.2.1, to clarify).
@jcarlson wrote:
Try this:
EDIT:
Prab
Classification: UNCLASSIFIED
Gregor,
Try the following found in
https://stackoverflow.com/questions/1888544/how-to-select-records-from-last-24-hours-using-sql
In MySQL:
SELECT *
FROM mytable
WHERE record_date >= NOW() - INTERVAL 1 DAY
In SQL Server:
SELECT *
FROM mytable
WHERE record_date >= DATEADD(day, -1, GETDATE())
In Oracle:
SELECT *
FROM mytable
WHERE record_date >= SYSDATE - 1
In PostgreSQL:
SELECT *
FROM mytable
WHERE record_date >= NOW() - '1 day'::INTERVAL
In Redshift:
SELECT *
FROM mytable
WHERE record_date >= GETDATE() - '1 day'::INTERVAL
In SQLite:
SELECT *
FROM mytable
WHERE record_date >= datetime('now','-1 day')
In MS Access:
SELECT *
FROM mytable
WHERE record_date >= (Now - 1)
select * from table where date_field > (now() - interval '24 hour');
LauraBoagey1
I have 3 layers all pointing to one data source with different definition queries  by dates. However, someone pointed out that this can be done better as we have to change the year date every year and they said we can write a query that doesnt need changing every year, but they didnt have time to tell me what the query would be.... could anyone help?
Current year is anything post 1st April 2022
Previous year is anything between 1st April 2021 and 31st march 2022
Old data is 31st March 2021 and before
These are the queries we currently have
Current - DATE_LOGGED >= '2022-04-01 00:00:01'
Previous - DATE_LOGGED >= '2021-04-01 00:00:00' AND DATE_LOGGED <= '2022-03-31 00:00:00'
Old - DATE_LOGGED <= '2021-03-31 00:00:00'
How do I write the query so that I dont have to change the year in the query every 1st April?
Thanks
Laura
Andrew_McLellan
I know this is an old post, but I believe there is a way to do this now in Arc Pro Definition Query with SQL
EXTRACT(YEAR FROM "Date_Field") = EXTRACT(YEAR FROM CURRENT_DATE - 365)
This will allow someone to have way to auto filter years in a date field by the current date year +- however many days. This might be helpful to others rather than hard coding dates in the definition queries if the map is used year over year on a living data set.
