Definition query UI/UX question
1082
02-03-2025 07:49 AM
AmyRoust
This is in ArcGIS Pro 3.3.0.
When I am setting up a definition query in Pro on my address point layer, there doesn't appear to be a function that reduces the options in the pick list when you start to enter a value. For example, let's say I'm looking for 400 Main St. If I type in 400 and click the drop-down, shouldn't I see a filtered list of addresses that start with 400?
I thought perhaps I needed to click the More button to load the full list of values, but even after doing that, my pick list gives me every possible option in the feature class.
If that's not how the definition query menu is designed to work, I want to put in a suggestion on ArcGIS Ideas because this isn't user friendly.
ZachBodenner
MVP Regular Contributor
I would definitely recommend putting in that idea, because I would like to kudo it.
Happy mapping,
- Zach
BarryNorthey
What happens if you click the drop down first and then enter 400?
AmyRoust
Same thing - no filtering occurs.
Bud
Legendary Contributor
@AmyRoust
Can you put a link to your idea in this post/question?
