Define Label Postion in Arcade
1514
04-28-2020 08:24 AM
RobertBorchert
Honored Contributor
There are lots of great formation options for labels using an Arcade expression.
Is it possible to define other attributes of a label in the same arcade expression
Halo,
Positions,
Preferred offset
Percentage of offset
etc..
There are tags to create a box and then color the box with an outline.  But I  am looing beyond that
XanderBakker
Esri Esteemed Contributor
Hi Robert Borchert ,
As far as I have seen, all those things you mention do not have methods to create an Arcade expression and manipulate them. Maybe the best thing to do is to create an idea (ArcGIS Ideas ) and explain in a more detailed way what your exact use case is.
Kory Kramer‌; do you know if it is on the roadmap to include more tags in the label definition to manipulate other properties as Robert is asking?
KoryKramer
Composite callouts are coming in ArcGIS Pro 2.6.  This may help to achieve what is being requested here.
Here is a sneak peek from the help (again, Pro 2.6, this is not available yet):
So complex labels can be set up like this:
