Default Toolbox and Geodatabase with Project Templates
3122
05-03-2019 02:13 PM
NathanHeickLACSD
I want to be able to make a Python toolbox the default toolbox in an ArcGIS Pro project.  I am making a project template and I am putting all my code into the Python Toolbox.  I have no need for the .tbx file that gets created automatically.  Is there a way to do this?  If not, is there a reason why?
The same thing kind of goes for my default geodatabase.  I am bringing in an FGDB with an empty schema from my project template.  I don’t need the extra blank file geodatabase that gets created.  I can delete it through Python and reset the default GDB to the one I had in the template, but it would be nice if it kept the original default geodatabase from the source project.
Tags (1)
ThomasColson
This topic is quite lively, with the response being a universal dislike of the extra toolboxes and FGDB's being created by Pro, especially with templates:
We've tried to workaround it by this:
Unfortunately you have to do this for each user of each computer, and new users are popping up as fast as "how do I get rid of the extra toolboxes and geodatabases" comments, and I've gotten quite a lot of negative feedback "Arc Map wasn't this complicated to use!". You also can't put the default "junk" on a network share as Pro performance suffers greatly when the default junk is on a network drive, and there's the danger of multiple folks using the same junk.
ThomasColson
NathanHeickLACSD
Well, thanks for clarifying that.  I noticed the extra settings, but it wasn't really what I was looking for.  The developers will have to address everyone's feedback.
JeremiahP
Agreed - I often find the automatic creation of a default toolbox and geodatabase very annoying. I just want an aprx at least 70% of the time.
ArcMap didn't do this, and I/we always have our own folder structures anyway, with multiple map documents referencing common data folders.
Please allow users the option to create aprx files *without* a default toolbox and gdb. We can always point to them later.
For now, I just have my create project settings pointing to a sandbox toolbox and gdb. And I have it set to not create a project folder.
