Default or Force column to store Upper Case?
1427
08-11-2021 02:15 PM
Labels (2)
LorindaGilbert
Hi All,
Working on setting up a project and the client has asked if there is a way to enforce a column's value to always be upper case.  I see the arcade function of Upper(value), tested it and it didn't do what I expected.
Any sage advice out there for how to do this?  It will be published to be used in a web app as well.
Lorinda
DavinWalker2
Attribute rules should be able to help you achieve your outcome.
LorindaGilbert
I tried it with an attribute rule.
var cmts = $feature.Comments
    Upper(cmts)
return cmts;
Applied after adding test string, still lower case.  Did I miss something in this one?  Did as a calculation rule, maybe it should be a constraint rule?
