Deep Learning Installation issue ArcGIS pro 3.0.0
4723
07-27-2022 10:20 AM
Labels (3)
AhmedHefnawy
Hi all,
I'm trying to install deep learning package in ArcGIS pro 3.0.0
i followed all steps but i face the following error:
the conda directory is missing, please repaire your arcgis pro instullation
arcgis pro cannot modify the default python environment
i tried to uninstall everything and install it again, but nothing work and still the same error.
old versions working well, i faced that only with Arch 3.0.0
DanPatterson
MVP Esteemed Contributor
From here
Install deep learning frameworks for ArcGIS—ArcGIS Pro | Documentation
you went here
deep-learning-frameworks/README.md at master · Esri/deep-learning-frameworks (github.com)
and followed the instructions to produce and activate the necessary clone with the installed packages?
... sort of retired...
CSIAdmin3
Hi Dan,
I have a new install of ArcGIS Pro 3.03, downloaded deep learning libraries for arcgis pro and get this error from the ProDeepLearning.msi. Deep Learning Libraries for ArcGIS Pro has not detected ArcGIS Pro 3.0.
The only download available from myesri is 3.03. Any ideas?? Thanks
DanPatterson
from deep-learning-frameworks/README.md at master · Esri/deep-learning-frameworks (github.com)
in this link
Deep Learning Package Installer Fails with ArcGIS Pro 3.0.3 · Issue #56 · Esri/deep-learning-framewo...
someone else is having problems with 3.0.3.  You should jump in there or at least follow the thread
muserum
Hi there, i was currently using "Train using AutoML" package in ArcGIS Pro 3.0.3. Yesterday i updated ArcGIS pro from 3.0.3 to 3.0.4 which was suppose to fix some minor patches. After the update the Deep learning library (train using AutoML) has disappeared. its no longer there. do you know if this library has been removed from the deep learning package?
