Deep Learning Essentials Install Issue
2917
09-13-2023 12:39 PM
Rory_Hogan
Hi everyone, I am trying to install the deep-learning-essentials package from github but when it says it has installed successfully it is not available in package manager. Has anyone else had this issue? I am using ARCGIS Pro 3.1.3
DanPatterson
MVP Esteemed Contributor
If you installed it using the instructions here, it is installed
Esri/deep-learning-frameworks: Installation support for Deep Learning Frameworks for the ArcGIS Syst...
Do a
>>> conda list
to see if the packages at the bottom of that page are indeed installed in the default environment (arcgispro-py3 )
... sort of retired...
DanPatterson
Do a
>>> conda list
Rory_Hogan
Thank you! Was able to see it under the Conda List, appreciate your help!
