Deep Learning Detect Objects - single feature query
1176
06-27-2024 09:29 AM
jennywilliams
I have one feature that I am trying to extract from all my images (UAV imagery at 0.04m pixel). I have approximately 150 training samples of that feature from which 81 chips have been created (though 2 are not right). However, when I Train the Deep Learning Model I get empty performance values for each Epoch, and when I look at the model_metrics the graphics are empty, with just the chip images side by side.
When I try to run the Detect Objects on the original training raster, I cannot select my DLPK stored locally, after copying the folder from a server (where it was originally created).
Am I missing a very basic step here?
Thanks
Train Deep Learning Model
Parameters
Input Training Data     G:\Users\jw75kg\Madagascar\Ankarafantiska_2022_2024_GuardianAppeal\Yam\UAV_Assessment\yam_holes_2022_Pachy_Train
Output Folder     G:\Users\jw75kg\Madagascar\Ankarafantiska_2022_2024_GuardianAppeal\Yam\UAV_Assessment\yam_holes_2022_Pachy_Train_DLmodel
Max Epochs     20
Model Type     FEATURE_CLASSIFIER
Batch Size     64
Model Arguments
Learning Rate
Backbone Model     RESNET34
Pre-trained Model
Validation %     10
Stop when model stops improving     STOP_TRAINING
Output Model     G:yam_holes_2022_Pachy_Train_DLmodel.dlpk
Freeze Model     FREEZE_MODEL
Data Augmentation     DEFAULT
Augmentation Parameters
Chip Size     256
Resize To
Weight Initialization Scheme
Monitor Metric     VALID_LOSS
Environments
Processor Type     GPU
Messages
Start Time: 07 June 2024 16:36:46
Learning Rate - slice(2.51188643150958e-08, 2.51188643150958e-07, None)
epoch      training loss        validation loss      accuracy             multi_label_fbeta    time
0          0.0                  NA                   00:00:03
1          0.0                  NA                   00:00:02
2          0.0                  NA                   00:00:02
3          0.0                  NA                   00:00:02
4          0.0                  NA                   00:00:02
5          0.0                  NA                   00:00:02
6          0.0                  NA                   00:00:02
Succeeded at 07 June 2024 16:43:22 (Elapsed Time: 6 minutes 35 seconds)
ShivaniPathak
Hi, if you are still facing this issue, is it possible for you to share the training data.
jennywilliams
Currently with ESRI support, working through a few options. thanks
