I have a point layer and a standalone table that I have joined based on their GlobalID/GUID field. I need to 'select by attributes' to pull out a date range for a report, but it fails with an Invalid SQL Expression error.
If I use the same expression on the point layer with no join, it works great. I've also tried doing this with a python/sql script outside of Pro, and I have the same failed results. I can query for anything except date range.
Is there any SQL syntax or rule that I would be violating by attempting this query on a joined table? Any ideas why this fails but other queries do not?
Enterprise 11.3/Pro 3.3.2
