Help
How can I set the user dataset privileges so 2 user can add edit update features in a dataset?
Solved! Go to Solution.
This is not possible in a file geodatabase. They need to be in separate feature datasets or file geodatabases.
It is possible with an enterprise geodatabase
https://pro.arcgis.com/en/pro-app/3.0/help/data/geodatabases/overview/types-of-geodatabases.htm
You could also use manage the data as a Hosted Feature Layer in ArcGIS Online.
