Data Interoperability Extension warnings
981
07-13-2023 09:19 AM
JasonBagwell1
Greetings,
Can someone please explain the following warning?  It comes up every time I run the data interoperability extension.  It doesn't seem to effect my data.  Can anyone tell me how to fix it?  Or, should I just not worry about it?  Never been able to figure it out.
NOT changing coordinate system of reader identified by keyword `SHAPEFILE_1' from `_NSRS11.SCIF_0' to `_NSRS11.SCIF_1' -- mapping file setting of `_NSRS11.SCIF_0' overrides coordinate system `_NSRS11.SCIF_1' read from file
Jason
Robert_LeClair
Esri Esteemed Contributor
The only thing I see on the internals about this is when there are space in the file path and also if the Feature Class or Shapefile starts with an underscore.  Does your input parameter have any spaces or leading underscores?
