Data downloaded from ArcGIS Rest Service which can open in QGIS but not ArcGIS Pro
2967
03-01-2024 10:37 AM
WilliamYu811
Hi there!
I downloaded several files located in "DynamicLayers" from an Taiwanese Governmental ArcGIS Rest Service server (https://sidewalk.cpami.gov.tw/arcgis/rest/services/DynamicLayer/MapServer)
by QGIS "Data Source Manager",
but after several exports, neither saving as Geopackage or as single ShapeFile
can be opened successfully in ArcGIS Pro.
When I import the layers under GeoPackage, It pops up this:
Adding layer under gpkgAdding layer under gpkg
If I export as SHP and execute import,
It can be loaded into "Map" Window and become visible like usual,
but when I try to open the Attribute Table, the query stucks suddenly and pops up like this:
Opening Attribute Table from loaded SHPOpening Attribute Table from loaded SHP
and the file can be loaded succesfully in QGIS without error:
QGIS can load without errorQGIS can load without error
The file ("Sidewalks_Width.gpkg") can be access here.
Thanks for your time with this post,
best regards,
William.
GeeteshSingh07
@WilliamYu811, not sure about the reason for this issue. But, here is the solution:
Open ArcGIS Pro >> Click Add Data drop-down >> Click Add Data from path >> Paste this URL :https://sidewalk.cpami.gov.tw/arcgis/rest/services/DynamicLayer/MapServer
Click OK.
The data will be added to the map.
If you want to export data from ArcGIS Pro, you can use "Export Features" gp tool: https://pro.arcgis.com/en/pro-app/latest/tool-reference/conversion/export-features.htm
Best Regards,
Geetesh
[email protected]
GeeteshSingh07
@WilliamYu811 , I was able to successfully add data using above workflow I mentioned:
Best Regards,
Geetesh
[email protected]
Brian_Wilson
Honored Contributor
If you can open the spatial part of a shapefile but not the attributes then you have somehow separated out the *.shp file from the *.dbf.  You have to keep all the shapefile parts together in the same folder.
