Customizing the Ribbon in Pro
3419
01-22-2016 08:43 AM
PaulStephenson
Had a couple of quick questions about customizing the ribbon in ArcGIS Pro.
Using the Customize the Ribbon interface I've found in that if I remove an item (the Analysis tab for instance) from the ribbon in I cannot add it again. I have the option to reset all customizations but the option to Add-> an item is always grayed out. Am I missing something here?
Would also like to set the customization by the project, not the machine. Can this be done at the project level?
Using ArcGIS Pro 1.1.1
DanPatterson_Retired
perhaps behaving as planned Customize the user interface—ArcGIS Pro | ArcGIS for Desktop
perhaps copying to a new tab with what you want rather than removing the whole tab
