Custom Projection in ArcGIS Pro
3050
11-12-2019 10:41 AM
MitchHolley1
MVP Alum
I have created a custom projection in ArcGIS Pro 2.4.2 (NAD 1983 UTM Zone 11N - Foot US), but ArcGIS Pro seems to handle the projection different than ArcGIS Desktop.  When I create a new custom projection in ArcGIS Desktop and change the Linear Unit, the False Easting value is automatically calculated.  But, when I do the same process in ArcGIS Pro, the False Easting value is not auto-calculated and remains at the default linear unit value of the original projection.
Process in ArcGIS Pro
Before changing Linear Unit:
After changing Linear Unit:
Process in ArcGIS Desktop
Notice the False_Easting value has changed!
Is this typical behavior?  Does the user have to determine a False Easting value for every custom projection?  This is causing data to plot incorrectly when importing the data into ArcGIS Pro.
HeatherSmith
Esri Alum
Hi Mitch,
Unfortunately, you have found a bug. Fortunately, this issue (tracked here) has been fixed in Pro 2.5, so you should not see it once this new version is released and you have upgraded.
DanPatterson_Retired
meter to US foot
Feet (u.s. Survey) to Meters | Kyle's Converter
500,000 m = 1,640,416.67 US feet
MitchHolley1
MVP Alum
Thanks, Dan.  I was just wondering why the user now has to do this conversion and manually input the value in instead of the software.  This could/will lead to an incorrect data entry.  It's just strange that the function is found in ArcGIS Desktop and not ArcGIS Pro.
Sound like ArcGIS Ideas‌ … probably due to web stuff
HeatherSmith
Esri Alum
Hi Mitch,
